Linear Actuator Automatic Reverse Travel
Discussion in 'General Electronics Chat' started by zambonya, May 8, 2009.
  1. zambonya
    Apr 17, 2009
    I am working on a project that requires the following:
    A NO button is pressed causing the linear actuator to travel forward, until hitting a NC limit switch. The actuator then travels backwards until it hits a another NC limit switch, causing it to stop. I have been experimenting with different circuits and have attached one diagram. If you look at my circuit drawing my problem is that when limit 1 is hit causing reversal the limit switch will close again causing continuous forward backward travel. Any comments are highly appreciated. Both relays are DPDT. Thanks
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    You have an even bigger problem. In the circuit shown, no current will ever pass through the motor.
  3. zambonya
    Apr 17, 2009
    Looks like I have attached both leads of the right relay to -12 V. Attached should be the corrected one. Thanks
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    It looks like you may need to put some kind of latch function across the reversing limit switch, otherwise as soon as the traveler moves off the switch, it would go back into the forward direction and just bounce back and forth.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Try this:
  6. zambonya
    Apr 17, 2009
    Thanks a lot wookie.
