Line voltages for audio
Discussion in 'General Electronics Chat' started by cumesoftware, May 6, 2009.
  1. cumesoftware
    Thread Starter Senior Member
    Apr 27, 2007
    1,330
    11
    I need to confirm if the line voltage for RCA connectors (for example, the ones used for audio output in TVs) is actually 0.350V RMS. Am I right?
    Also, is it correct to assume that the line voltage for headphones is 0.316V RMS?
    Thanks in advance.
  2. studiot
    Nov 9, 2007
    5,005
    515
    A quick shufty at the specifications pages of some audio equipment will show that 'line levels' can vary between 0.1 and 1 volt in normal operation.
    Don't forget that impedance level also play a part 600 ohms, 47k ohms or 10k ohms being common input values.
    This applies to both domestic and professional equipment. That is why we have input potentiometers.
  3. cumesoftware
    Apr 27, 2007
    1,330
    11
    Thanks for you reply, studiot. But I need to know the exact standard RMS voltage as used in low level RCA sockets, like the ones found in the back of TVs and VCRs, or in the back of audio amplifiers.
    Also, what is the standard RMS voltage for use with headphones?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The RCA connector has no bearing on audio levels. Audio signal levels are somewhat standardized - http://en.wikipedia.org/wiki/Line_level.
    Headphones are driven by amps fed by audio sources at standard signal levels. The amp will have a fixed gain, so the audio signal will be attenuated by means of a level pot.
  5. cumesoftware
    Apr 27, 2007
    1,330
    11
    So I can assume that the standard nominal voltage normally used in headphones is 0.316V RMS.
    And what is the standard nominal voltage normally found in RCA connectors? Is it the same? Or is it 0.350V RMS?
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Here I found an atricle on line level:
    This quote comes from this page:
    http://lenardaudio.com/education/11_cable.html
    Greetings,
    Bertus
  7. studiot
    Nov 9, 2007
    5,005
    515
    At the risk of repeating myself
    Look at the specifications for the particular equipment concerned.
    Here are some quick ones
    Sony Audio in/out -7.5 dBs ( 0 dBs = 1 vrms into 47k)
    Panasonic Audio in -10 dBv Audio out - 8dBv both more than 47k headphone -30dBv into 8 ohms
    Yelo 5.1 channel 0.5 volts pk to pk stereo mix 2volts pk to pk
    As you can see they vary from manufacturer to manufacturer. There is no standard.
    As I also noted before you also need the impedance to calculate voltages. This is very important.
  8. cumesoftware
    Apr 27, 2007
    1,330
    11
    I'm not analysing any equipment in particular, but I'm projecting an amp that uses a pair of RCA sockets and a TRS jack socket as inputs. You can choose the input you want (RCA or TRS) via a selector switch. I believe they use different voltage levels. Hence my question.
    I want to base myself on standard "should be" values, and not on the values measured from any particular equipment. I've heard that values for RCA plugs can be 0.775V RMS, others say they are about 0.350V RMS. I cannot base myself on suppositions.
  9. studiot
    Nov 9, 2007
    5,005
    515
    Do you understand what I said about impedance?
    I though you knew more about electronics?
  10. cumesoftware
    Apr 27, 2007
    1,330
    11
    Just found out that for RCA sockets, the standard line level is 0.5V RMS (if you take it from a SCART plug).
  11. studiot
    Nov 9, 2007
    5,005
    515
    If you say so it must be true.
    However if you connect the output of a Panasonic Nv-DX110EG to the input of a Sony EV-C2000 and measure the 'voltage' you will find it is three times the 'voltage' if you connect the same Panasonic to a Tascam 424.
    This is because the input impedance of the Sony is 47k and the Tascam is 10k, the output impedance of the Panasonic is the same 47k in both connection cases.
    I won't waste my time again if you don't want to discuss sensibly.
  12. Darren Holdstock
    Feb 10, 2009
    262
    11
    All good replies to the OP. Even the old professional standards aren't so standard any more. It used to be that you could drive a 775 mV rms sine wave into an amp and that gave the maximum output without clipping. Now it seems the line levels are higher, presumably to minimise interference pickup on the long cable run between the mixing desk and the amp.
    There are no connector-specific line levels that I've come across. OK SCART is now 2 V rms into 10 kΩ, but then SCART is more of an integrated system than a mere connector. And it still varies - all my SCART sources are at slightly different levels. Consumer audio gear is -10 dBV in theory, but in practice the levels are impossible to match with any degree of accuracy as the equipment manufacturer has no control over the levels of the source audio, whether that's CD, tape, radio, DVD or whatever.
    There are no standards for headphone levels either. Maybe you need to think in terms of peak audio levels at the input, and match that to the peak power level the headphones will take, and then back it off a tad. 'Scoping up a CD source would probably be safest, as they've got a good dynamic range and will have a higher peak:rms ratio (or crest factor). The latter is a whole 'nother can of worms, but needs to be considered as an rms line level doesn't guarantee a maximum peak level.
