Line to Guitar pedal
Discussion in 'General Electronics Chat' started by Precious Molina, Sep 13, 2015.
  1. Precious Molina
    Sep 6, 2015
    23
    looking for alternative to transfomer(impedance converter)
    im going to use soundcard lineout to guital pedal
    is the transistor (common base) can do this impedance convert to higher?
    or any suggestion?
  2. blocco a spirale
    Jun 18, 2008
    1,459
    369
    Are you sure you need match impedances? It isn't necessary when going from low to high, in fact, this is normally the goal.
  3. Veracohr
    Jan 3, 2011
    559
    77
    I think I remember reading somewhere that guitar pickups have a source impedance of several thousand ohms usually, so use a pot to reduce the voltage going into the pedal & call it good.
