line level audio switch matrix - FF state changes
Discussion in 'The Projects Forum' started by Fishman_Tx, Sep 24, 2009.
  1. Fishman_Tx
    Sep 24, 2009
    Using a simple Dual D FF as indicated and using a Schmitt trigger with the "momentary on" pushbutton w/debouncing; I want to latch/drive 2 sections of a 4066 quad bilateral switch for the switching of line level signals. Tho /Q is tacked to D. Can /Q be tapped also to a switch actuator of the 4066? Or would it be better using Master/Slave configuration? The purpose is to switch from one active signal path to another (A/B switch). This will be multiplied into a digital signal switching matrix for my guitar rig. Is there a particular Dual D FF IC that would be recommended? Will the Schmitt give sufficient "edge" to toggle the state? I would prefer to have leading edge vs trailing for timing reasons.
    It's been a long time away from design work, so forgive my ignorance or "thickness". I've a lot of re-studying to do on the basics....
    Thx!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A 4013 should work fine. CMOS has no problem driving several other CMOS load. See fan-out on the data sheet.
  3. Fishman_Tx
    Sep 24, 2009
    But no problem with half tapping /Q for D as well as the 4066 then?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
