Line level audio out to pre-amp mic
Discussion in 'General Electronics Chat' started by Solidfrost, Jun 6, 2014.
  1. Solidfrost
    Jun 6, 2014
    5
    Hello all,
    I've got a 0.5V line level audio out source that I need to connect to a pre-amp mic in (which shows 14.2V).
    I found something like this searching around, but I'm not sure if this applies:
    Code ( (Unknown Language)):
    1.
    2.                       C1
    3. +Line level in      --||----R1----+--     +Mic level output
    4.                                   |
    5.                                   |
    6.                        +----R2----+
    7.                        |
    8.      Ground (input)----+--------------- Ground
    9.
    10.
    11. R2 = ?
    12. R1 = ?
    13. C1 = ?
    14.
    I'm slightly new to designing circuits, and have no clue if this is what I need. Any help is so much valued and appreciated.
  2. ericgibbs
    Jan 29, 2010
    2,600
    394
    hi,
    The C1 will block the DC component, the 14.2V and allow the AC audio frequencies to pass through. A value of 100nF to 470nF would be a reasonable test value.
    The R1 and R2 resistors will attenuate the AC audio signal, a reasonable test value would be 10K for R1 and R2.
    If the audio is attenuated too much then make R2 47K or higher, if not enough make R1 higher.
    Not knowing the details of the input and output resistances of the Line and Mic the C1,R1,R2 values are 'typical'.
    The 14.2V is higher than I would expect on a preamp input.?
    How did you measure it.?
    E
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    why do you need to run line level OUT to a line INPUT mic? shouldnt the mic OUTPUT go to the preamp INPUT?
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    Some mic inputs have DC on them to power electret microphones. Rather than have that DC go through the divider, I recommend moving C1 to the other side of R1, so the circuit looks like a T with R1 on the left going to the source, C1 on the right going to the input, and R2 to GND.
    Multimedia PC Level 2 (1999) defined the line input (max volume, no clipping) as -10dB, where 0dB is consumer level, 1mW into 700 ohms (yes, 700). This works out to 0.221 Vrms. OTOH, PC99 design guide (1998) defines the full scale inputs as line = 2.0Vrms and mic = 0.1Vrms. That's a 26dB difference. I recommend 20K for R1 and 1K for R2. If that is too much or too little, adjust R2 only.
    ak
  5. Solidfrost
    Jun 6, 2014
    5
    Thank you all for your suggestion and responses. I'll try to answer your questions as best as I can:
    What I'm actually trying to accomplish: I have a low level audio source I need to wire directly into a Motorola mobile. The mobile has a built in pre amp for the mic line.
    E, I took a digital multimeter set on DC, red lead into MIC wire and black lead into GND
    AK,
    I believe that's how this works!
    I just would like to be sure so I won't fry anything or damage any components.
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    use a capacitor around 1 mfd to isolate the dc from the audio line. it should couple the audio through.
  7. Solidfrost
    Jun 6, 2014
    5
    The way you specified above with C1 on the higher voltage side?
    Which way would the polarity of C1 be?
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    if it were nonpolerized it wouldnt mater. otherwise, + to the radio side.
  9. Solidfrost
    Jun 6, 2014
    5
    Ok so I gathered everyone's suggestion to this:
    1.                                     C1
    2. +Line level in      ------R1----+--||--     +Mic level output
    3.                                   |
    4.                                   |
    5.                        +----R2----+
    6.                        |
    7.      Ground (input)----+--------------- Ground
    8.
    9.
    10. R1 = 20K
    11. R2 = 1K (adjust this to attenuate)
    12. C1 = 1uf
    13.
    I don't want to sound stupid by asking this, I'm just trying to make sure I understand.
    You mean: too much sound = higher R2 resistance
    Too little sound = lower R2 resistance?
  10. BobTPH
    Jun 5, 2013
    807
    121
    Nope, the other way around. If it is too loud, reduce the value of R2.
    The output voltage is:
    R2 / (R1 + R2) * Vin
    Bob
  11. Solidfrost
    Jun 6, 2014
    5
    Thanks for that formula!
    I have this: 271-343
    http://www.radioshack.com/product/index.jsp?productId=2062308
    A.) Could I use this in place of R2?
    B.) How do I hook it up? It has 3 pins.
    C.) Does the following schematic look correct?
    1.                                        C1
    2. +Line level OUT(.5VDC)  ------R1----+--||--     +Mic level (14.2)VDC
    3.                                     |
    4.                                     |
    5.                          +----R2----+
    6.                          |
    7.       Ground (out)   ----+--------------- Ground
    8.
    9.
    10. R1 = 20K
    11. R2 = 1K  OR Potentiometer/Trimmer -(adjust this to attenuate) Lower Value to Decrease sound, Higher value to Increase Sound
    12. C1 = 1uf
