Line following circuit question.
Discussion in 'The Projects Forum' started by allhuber, Nov 15, 2011.
  1. allhuber
    Nov 5, 2011
    12
    Hey AAC Community,
    Recently I bought a single motor basic tamiya car. After watching some line following robots, I was thinking if it is possible to have a single steering line following. What I mean is the car's rear wheels will be driven forward with out steering, like a tricycle, then the line following circuit will control the front single wheel .
    I saw this example using transistors and other easy to find components.
    http://www.youtube.com/watch?v=EdAHQL1jRfI&feature=results_main&playnext=1&list=PL40FDB3EA1305CB22
    http://farm4.static.flickr.com/3463/3709205059_6476ae5f05_z.jpg?zz=1
    I was wondering if it possible to place a servo or dc motor to steer the car in conjunction with line following circuit. If possible, can pls advice me how?
    Thanks Thanks!! :]
  2. wayneh
    Sep 9, 2010
    12,379
    3,235
    I'm no expert, but I think you could use use the difference between the control signals of the two sides in the given circuit, and use that information to move a servo. This would give a degree of proportionality and solve the problem of having both motors "on" at the same time. That works for propulsion but not steering.
