Rich (BB code):
//Title: LINE FOLLOWING COMPETIIION //
#include <18f4550.h>
#fuses HS, NOWDT, NOLVP, NOPROTECT
#device ADC =10
#use delay (clock =20M)
#include <lcd.c>
//Configure LCD
#Define LCD_ENABLE_PIN PIN_D0
#Define LCD_RS_PIN PIN_D1
#Define LCD_RW_PIN PIN_D2
#Define LCD_DATA4 PIN_D4
#Define LCD_DATA5 PIN_D5
#Define LCD_DATA6 PIN_D6
#Define LCD_DATA7 PIN_D7
//Define IRSensor // BUTTON
#Define IR1_switch PIN_A0
#Define IR2_switch PIN_A1
#Define IR3_switch PIN_A2
// Define LED
#Define LED_1 PIN_B3
#Define LED_2 PIN_B4
#Define LED_3 PIN_B5
// Define MOTOR
#Define FWD_LEFT PIN_C4
#Define RVS_LEFT PIN_C5
#Define FWD_RIGHT PIN_C6
#Define RVS_RIGHT PIN_C7
// Define PWM
#Define PWM1 PIN_C1
#Define PWM2 PIN_C2
Void main()
Lcd_init();
//Configure Input Outpot Pin
set_tris_a(0x0f);
output_a(0b11000111);
set_tris_b(0x00);
output_b(0b00111000);
Set_tris_c(0x00);
output_c(0x00);
//Configure PWM pin
setup_timer_2(T2_DIV_BY_4,254,1);//PWM OUTPUT CONFIGURATION
setup_ccp1(ccp_pwm); //PWM 1 DUTY CYCLE CONFIGURATION
setup_ccp2(ccp_pwm); //PWM 2 DUTY CYCLE CONFIGURATION
//Mention Title
printf (lcd_putc, "\fLINE FOLLOWER A+");
while(true)
if(!input(PIN_A1)) // follow line
while(!input(PIN_A1))continue;
// MOTOR1
Output_low(PIN_C4);
Output_high(PIN_C5);
output_low(PIN_B3);
output_high(PIN_B4);
output_low(PIN_B5);
set_PWM1_duty(100);
// MOTOR2
Output_high(PIN_C6);
Output_low(PIN_C7);
printf(lcd_putc,"\fFOLLOW LINE");
printf(lcd_putc,"\nFOLLOW LINE");
set_PWM2_duty(100);
if(!input(PIN_A0)) // Turn Right
while(!input(PIN_A0))continue;
// MOTOR1
Output_high(PIN_C4);
output_high(PIN_B3);
output_low(PIN_B4);
output_low(PIN_B5);
set_PWM1_duty(100);
// MOTOR2
Output_low(PIN_C7);
printf(lcd_putc,"\fON");
printf(lcd_putc,"\nTURN RIGHT");
set_PWM2_duty(100);
if(!input(PIN_A2)) // Turn Left
while(!input(PIN_A2))continue;
// MOTOR1
Output_low(PIN_C4);
output_low(PIN_B3);
output_low(PIN_B4);
output_high(PIN_B5);
set_PWM1_duty(100);
// MOTOR2
Output_low(PIN_C6);
Output_low(PIN_C7);
printf(lcd_putc,"\fTURN LEFT");
printf(lcd_putc,"\nON");
set_PWM2_duty(100);
