line follower problems with 7400, L7805 and breadboard
Discussion in 'The Projects Forum' started by kenchak, Jan 25, 2011.
  1. kenchak
    Jan 25, 2011
    I am beginner of robotics and have decided to make my first line follower robot using logic gates ( L7805 and L7812 for voltage regulators, LM339 comparator and L239D
    motor driver). i have made all connections an my bread board. At first instance everything seems to be working fine but suddenly i have met with some problems,
    1.Voltage regulator 7812 heated up and become unusable(i.e it is not showing correct reading at all)
    2.voltage regulator 7805 working some times and not showing readings sometimes( input side reading drops to 1V even i am feeding it with 10V from battery eliminator and
    output side shows reading same as input side and i have connected De-coupling capacitors of 0.1μF on each side)
    3.7400 posing problems in bread board when I tested it with LED they wont lit up even the output is high and only lit up when corresponding pins are touched with a probe and pin 3 is μshowing continuity with ground.
    please tell me if there could be any problem with breadboard itself.
    Could anybody please guide me..
    Thank you in advance.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Can you post the complete schematics?
    Perhaps also a couple of photos of the build circuit on the bread board.
    Bertus
  3. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    More details are definitely in order for this problem to be solved.
    Include what voltages are being fed into the regulators, 5 volt and 12 volt. If the input voltage is large or the current draw is significant, as can be expected when running motors, good heat sinking is necessary on the 7805 and 7812 parts...
