LINE FOLLOWER coding almost done ,, need checking help
Discussion in 'Programmer's Corner' started by x.macubex, Feb 19, 2010.
  1. x.macubex
    Feb 17, 2010
    ic used atmega16
    l293d
    notes -
    * I have used codevision of coding so check heades
    if using avrstudio ,, and also direct refrence like PINA.1
    is not avialable in avrstudio ,,
    * adc fxn not used
    * ports used
    - pin 33 to 40 for sensor arrays (PORT A),,
    - for PWM signal ie the one going to enable pin of h bridge
    OC1B pin 18
    oc1A pin 19 (PORT D)
    - pin 22,23,24,25 is given to the i/p of the L293d ie i/p 1,2,3,4 in order (PORT c)
    #include <mega16.h>
    #include <delay.h>
    #include <stdio.h>
    #define FWD 0xAA
    #define REV 0x55
    #define R 0x22
    #define L 0x88
    #define CW 0x99
    #define CCW 0x66
    #define STOP 0x00
    #define B 0xFF
    #define RSPEED OCR1AL
    #define LSPEED OCR1BL
    #define SPEED0 255
    #define SPEED1 0
    #define SPEED2 0
    #define SPEED3 0
    #define MAX 3
    #define HMAX 1
    void move (unsigned char dir);
    unsigned char i,rdev,ldev,ip,dir,dirl,history[MAX],hcount=0,rotpow;
    unsigned char rep=0,prev=0;
    void main(void)
    // Input/Output Ports initialization
    // Port A initialization
    PORTA=0x00;
    DDRA=0x00;
    // Port B initialization
    PORTB=0x00;
    DDRB=0x00;
    // Port C initialization
    PORTC=0x00;
    DDRC=0xFF;
    // Port D initialization
    PORTD=0x00;
    DDRD=0x30;
    // Timer/Counter 0 initialization
    TCCR0=0x00;
    TCNT0=0x00;
    OCR0=0x00;
    // Timer/Counter 1 initialization
    // Clock value: 921.600 kHz
    // OC non inverting
    // I/p Capture on Falling Edge
    TCCR1A=0xA1;
    TCCR1B=0x0A;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0xFF;
    OCR1BH=0x00;
    OCR1BL=0xFF;
    // Timer/Counter 2 initialization
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00; // disconnect occ2
    // External Interrupt(s) init
    MCUCR=0x00;
    MCUCSR=0x00;
    // USART initialization
    UCSRA=0x00;
    UCSRB=0x18;
    UCSRC=0x86;
    UBRRH=0x00;
    UBRRL=0x07;
    // Timer, counter, Interuptor init
    TIMSK=0x00;
    // Analog Comparator initialization
    ACSR=0x80;
    SFIOR=0x00;
    while (1)
    if(rep<255)
    rep++;
    if(prev!=PINA)
    prev=PINA;
    printf("%u\r",rep);
    for(i=0;i<8;i++)
    printf("%u\t",(prev>>i)&0x01);
    rep=0;
    if(PINA!=255)
    rotpow=255;
    ldev=rdev=0;
    if(PINA.3==0)
    rdev=1;
    if(PINA.2==0)
    rdev=2;
    if(PINA.1==0)
    rdev=3;
    if(PINA.0==0)
    rdev=4;
    if(PINA.4==0)
    ldev=1;
    if(PINA.5==0)
    ldev=2;
    if(PINA.6==0)
    ldev=3;
    if(PINA7==0)
    ldev=4;
    if(rdev>ldev)
    move(R);
    if(rdev<ldev)
    move(L);
    if(rdev==ldev)
    move(FWD);
    else
    for(i=0,dirl=0;i<MAX;i++)
    if(history==L)
    {dirl++;}
    if(rotpow<160)
    {rotpow=160;}
    if(rotpow<255)
    {rotpow++;}
    if(dirl>HMAX)
    {move(CW);}
    else
    {move(CCW);}
    PORTC=dir;
    if(dir==L || dir==R)
    hcount=(hcount+1)%MAX;
    history[hcount]=dir;
    LSPEED=RSPEED=255;
    i have done the above code ,, the code seems to be flaw less ,, i cant get what the problum is ,, there r two moters ,, icant get the motor 2 to work ,, i checked weather its in working condition ,, plz check the above code ,, so that ya can find any errors ,,
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You need to provide us with a schematic so that we can see first hand how you have wired things up.
    hgmjr
