Lin/Lout
Discussion in 'General Electronics Chat' started by cookes3, May 14, 2014.
  1. cookes3
    May 14, 2014
    I am reporting on a science project that involves an EPG monitor and have to discuss what Lin/Lout refers to. I honestly just have no idea what it means when referring to electric circuits. Any help?:)
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    line in, line out. references a low level usually 600 ohm audio cable connection between equipment.
    cookes3 likes this.
  3. #12
    Nov 30, 2010
    16,685
    7,324
    Line level signals are usually in the range of 1.1 volt peak. Just know you are dealing with a signal that is large enough to be well defined compared to local noise, and isn't much higher than a volt or two.
    Theoretically, it is .775 volts RMS driving a 600 ohm load, for a result of one milliwatt.
    In practice, it varies.
