Limiter switch
Lubby
Joined Feb 20, 2007
6
Hi there,
I looking to put together a system that include a motor that moves back and forth across a linear track. I was planning on using a limiter switch (DPDT) on either end to switch the polarity to send the motor back and forth. I am just not certain how to wire it as a three way switch.
Another though i'd had was using two momentary push switches on either end which would send a momentary pulse to a second switch that would change the polarity - but i do not know what this switch would be called - a switch that would DPDT with a momentary pulse and remain that way until another pulse switches it back.
Any ideas?
Lubby
SgtWookie
Joined Jul 17, 2007
22,230
See the attached for a possible solution using a single DPDT ON-ON toggle switch mounted on the carriage with your motor.
Yours would be similar, except instead of the stops on a rotating plate, there needs to be a stop at either end of your carriage's travel for the switch handle to contact.
