Limit current without affecting voltage
Discussion in 'General Electronics Chat' started by peck68, Oct 20, 2010.
  1. peck68
    Nov 27, 2009
    73
    Hey haven't posted here in a while,
    Anyway I'm interested in making a phone charger via my laptops USB port.
    The reason why a USB is good is because the output on my charger is 5V at 800mA.
    However a USB can only provide 500mA, less than that if that.
    So i decided 300mA would be a good safe option to choose... (a little more than half the max rating)
    So how do i limit the current to 300mA without reducing the 5V going to the phone?
    You cant particularly use resistors because that would drop the voltage, wouldn't it?
  2. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Q: "So how do i limit the current to 300mA without reducing the 5V going to the phone?"
    A: You may not be able to ( or need to ) it depends upon the V vs I characteristic of the phone in changing.
  3. tom66
    May 9, 2009
    2,613
    214
    First, the 500mA limit on USB ports is rarely implemented. You can usually draw 1A from them without tripping them. They have short circuit and overload protection built in anyway. In my experience this is shared between ports, so a failure in one device will shut down all other devices but it does not affect the computer.
    It is next to impossible to drop current without changing voltage, however, many chargers short the data lines on the USB cable together to notify the phone that they can provide a lot of current, whereas the computer doesn't, so this may be enough to tell the phone to go to a slow charge mode.
  4. John P
    Oct 14, 2008
    1,638
    225
    I suppose you could have a low-resistance logic-level MOSFET that's turned on most of the time, and an amplifier checking the voltage drop across a small resistance and limiting the current flow through the FET if it gets too high. Sounds reasonably straightforward, but there would be a small amount of voltage loss.
  5. R!f@@
    Apr 2, 2009
    8,787
    771
    If one can charge a phone via USB by using a data cable than U do not need a separate charge.
    If u are planning to build a charger cause ur phone does not charge when connected using USB data cable, then it will never charge thru any or modified USB charger that has a current limitation at 500mA.
    Point is if the phone has the capability to charge from 5V at 500mA, then u do not need to make anything. Just connect the appropriate USB cable and use a proper USB port
  6. t06afre
    May 11, 2009
    5,939
    1,222
    A USB port will not give more than about 100mA. Unless the device are able to negotiate more current
  7. tom66
    May 9, 2009
    2,613
    214
    This is true but it is rarely implemented, which is why you can get devices like mini hotplates working on USB with no enumeration chip.
  8. R!f@@
    Apr 2, 2009
    8,787
    771
    What I have seen from later mobo's. 500mA is possible.
  9. marshallf3
    Jul 26, 2010
    2,358
    201
    There are plenty of bench power supplies that are capable of limiting current while keeping the voltage at the same level instead of just shutting down so obviously it can be done. I have one at work that operates in that manner.
    Might not be so hard to do if I thought about it for a while but it's late.
