Lil info regarding UPS automation
Discussion in 'General Electronics Chat' started by assuc, Jan 3, 2014.
  1. assuc
    Mar 23, 2012
    77
    Greetings,
    I was thinking that in UPS(inverter) the automatic connection/disconnection of the battery charging works via relay(electromechanical) or Mosfet based in today's modern type system,
    what actually gets connected(shorted) the positive(+) or the ground(-); in ac mains let say the neutral or the live(phase)?
    Above query solved...
  2. #12
    Nov 30, 2010
    16,685
    7,323
    1) nobody could guess without a model number.
    2) you don't have to disconnect a battery charger to stop it from float charging the battery 24/7.
    3) therefore, it probably doesn't get disconnected.
  3. assuc
    Mar 23, 2012
    77
    its not about model number its about the working i want to know
  4. #12
    Nov 30, 2010
    16,685
    7,323
    Do you think every manufacturer does it the same way?
  5. assuc
    Mar 23, 2012
    77
    I don't know how manufacture do it I m just asking what is the best suitable way
  6. #12
    Nov 30, 2010
    16,685
    7,323
    But your first post asks, "What is the actual way?"
    Depends on the manufacturer.
    In my opinion, the best suitable way is: the float charger probably never gets disconnected.
    I run my lawn mower battery that way. I have kept a truck in storage for a year with that method, and it works. The batteries don't sulphate and they are always ready for work, which is exactly the definition of what a UPS needs.
  7. assuc
    Mar 23, 2012
    77
    Alright, that means battery never gets disconnected and that is done because to maintain battery life?
    if for example u want to charge the battery for a typical level of 13.5V such that when it attains that level it disconnects .... so what should be cutoff(positive or negative) of the charger in UPS to disconnect the circuit when battery not in use?
  8. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Either method would work.
  9. assuc
    Mar 23, 2012
    77
    As to why majority prefer it to be positive?? Does that anything to do with the efficiency or something else?
  10. #12
    Nov 30, 2010
    16,685
    7,323
    It's easier to do the math in your head when you use positive numbers.
  11. BillB3857
    Feb 28, 2009
    2,402
    348
    If you disconnect the battery from an Uninterruptible Power Supply, wouldn't that defeat the Uninterruptible part?
  12. assuc
    Mar 23, 2012
    77
    Ahan, thanks now I got it....
  13. Anaandrew01
    Mar 24, 2014
    No, not at all. Because battery is the most important thing in the UPS
