Lightning detector tester
Discussion in 'Wireless & RF Design' started by samuel.whiskers, May 21, 2014.
  1. samuel.whiskers
    Mar 17, 2014
    95
    I'm building the lightning detector from techlib.com - schematic from that webpage attached.
    It is apparently a simple receiver tuned to receive RF signals at approx 300kHz emitted by lightning.
    The author of the circuit shows a simulator circuit you attach to the antenna of the detector.... I have built this, and it seems to act the way the author suggests - but I was wishing to build a simple transmitter to test the detector in a real sense - would only need to transmit several inches or so. I've thought of making a 555 oscillate at 300kHz and running an antenna from the 555 output....
    Would this work?
    Any other suggestions to make a burst of 300kHz RF??
    (As indicated above - below circuit is from techlib.com - by C.Wenzel )
  2. Alec_t
    Sep 17, 2013
    5,948
    1,129
    Try a piezo gas igniter.
  3. samuel.whiskers
    Mar 17, 2014
    95
    I've seen that one suggested - will give a try.... I have an old Jacobs Ladder in a box somewhere as well, I figure it would probably do the same, but I was also hoping to actually reproduce in a circuit what the circuit is designed to detect.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    it is just looing for a burst of wideband noise. if you have an old fashoned buzzzer, they kind with a set of contact points and a coil, that will also work. 300 khz is just used on that circuit so there can be some selective gain to keep out broadcast am stations.
  5. Alec_t
    Sep 17, 2013
    5,948
    1,129
    You could also try holding the circuit close to an operating CFL or SMPS.
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    on the same circuit site ia a simple lightning simulator for testing lightning detectors.
  7. samuel.whiskers
    Mar 17, 2014
    95
    I've built that in preparation for completing the detector tonight, was hoping to try actually transmitting some RF to trigger it also....
  8. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It could also be done by dragging a wire across a piece of rusty metal, with a decent amperage PSU (like a 12v battery charger).
  9. samuel.whiskers
    Mar 17, 2014
    95
    Well, so far the lightning simulator seems to do nothing.... but the fluorescent tube over my bench gets the detector flashing when it starts! I'll assume this means I'm working, and I'll wait for a storm.... :)
