Lighting transformers
ISB123
Joined May 21, 2014
1,236
Hello, while I was looking for some transformers for a PSU build I stumbled upon "lighting transformers" which were fairly cheap, most likely because they are mass produced. To me they look like standard torrid transformers. On label it says "intended for use in halogen lighting only." Is it because they have thermal switch built in?
Specs:
250W
220V/11.5V 50Hz
joeyd999
Joined Jun 6, 2011
5,285
Specs:
250W
220V/11.5V 50Hz
Take another photo with the electrical ratings showing, please.
ISB123
Joined May 21, 2014
1,236
This one has more power but the rest is the same. Spec. for 250w
Weight:2.6kg
Height:48mm
Radius:127mm
Eff:95%
Hypatia's Protege
Joined Mar 1, 2015
3,228
Beware language barriers! If 'halogen lighting' indeed refers to 'incandescent's (as one would expect) then all's well and good (i.e. I agree with @joeyd999 {Post #4}) -- On the other hand should said devices be designed as ballasts for metal halide lamps, you may expect them to be current limited (via leakage inductance), to operate at rather high OC EMFs and, perhaps, be wired/wound as 'auto-transformers'...
Best regards and good luck!
HP:)
ian field
Joined Oct 27, 2012
6,536
HP:)
Its often referred to as; "low voltage lighting" - so an auto-transformer could potentially be a contradiction in terms.
Toroids probably don't like large voltage transients - so large inductive loads that produce a big fat spark when you break the current, could make you wish you'd included a primary fuse.
Hypatia's Protege
Joined Mar 1, 2015
3,228
I agree assuming the intended lamps are indeed incandescents (which, based upon labeling, etc. seems to be the case) -- as opposed to HIDs
I'll take your word for it - but inasmuch as the 'why of it' escapes me - please explain?:confused::)
Best regards
HP:)
ISB123
Joined May 21, 2014
1,236
I found the manufactures datasheets. It says that transformer has a thermal switch on the primary winding.
MaxHeadRoom
Joined Jul 18, 2013
28,696
Unfortunately in some instances it is a thermal type fuse and if buried without the ends exposed, it renders the Tfmr useless if and when it blows, if one is lucky the the ends ARE exposed and can be shunted out.
Max.
ian field
Joined Oct 27, 2012
6,536
Best regards
HP:)
AFAICR: They have less turns per volt than a conventional transformer - therefore; greater voltage stress on the insulation.
