lighting question
Discussion in 'General Electronics Chat' started by xx_l, Sep 4, 2014.
  1. xx_l
    Sep 4, 2014
  2. studiot
    Nov 9, 2007
    5,005
    515
    I see that Interior-Deluxe has an onsite electrician and a customer services department.
    Ask Them
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Since you are putting a 10.5W lamp in a 40W fixture, what is to worry?
    I wouldn't own a lamp fixture made out of paper mache... I like mine to be steel!
    Metalmann likes this.
  4. crutschow
    Mar 14, 2008
    13,505
    3,379
    From the web page, the lamp takes an E27 bulb which has a 27mm thread. The BR-30 bulb is apparently a standard E26 USA bulb with a 1" (26mm) thread. According to this, the two are "usually" interchangeable, so no guarantees.
  5. mcgyvr
    Oct 15, 2009
    4,791
    976
    holy crap.. $125 for a paper pulp light fixture.. :eek:
    b1u3sf4n09 likes this.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    As said, you most likely can use the E26 bulb in the E27 socket.
    The other way aurond would not fit.
    I am worried about the diameter of the bulb, if it would fit inside the lamp.
    Also it is strange that people will pay so much for "design".
    Bertus
