Like this if it's a deep box............
No need to fuse then.
Oops, I forgot.
You may be keeping the switch too.
Oops, I forgot.
But if I have an approved box for the housing doesn't the bond wire be left floating?Worse. Connecting bond to neutral at any place besides the breaker box is both a code and a safety violation because it intentionally connects bond to a current carrying conductor.
The bare wire in the box. And yes it's an equipment groundING conductor. Not a bonding wire. NECNow I'm confused. What is this ground wire of which you speak?
Yes. That's why it's confusing. When you arrive at an approved plastic box, the bond wire might find a home on the metal bracket of a wall switch or a duplex receptical, but bolting the bond wire to a plastic box accomplishes nothing. If there is nothing to connect it to, you just put a wire nut on it so it doesn't accidentally touch any power wires.But if I have an approved box for the housing doesn't the bond wire be left floating?
Do you mean non-conducting, as a plastic box. Then yes leave it unconnected.So my thought was that the third wire would be left unconnected because I don't have the switch inside a conductive box.
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Duane Benson
