I just hav this very basic amplifier circuit ( in attachment ) which gives 4 volts peak to peak output... I just need to light up an LED fed by the output of the amplifier.. The Problem is, the LED doesnt light up!! ( even if 4 volts is way above the forward voltage of LED)..
I need help on lighting up the LED from the output of the amplifier.. I dont want to use any transformers.. What adjustments can I make so that it lights up ( it wil blink in 10 kHz actually)..
Thanks for ur help in advance...
