Lighting a Ghost costume, Need suggestions
Discussion in 'General Electronics Chat' started by Coopette, Sep 21, 2012.
  1. Coopette
    Sep 21, 2012
    I am making a Starcraft Sarah Kerrigan Ghost costume which lights up. When I get it finished I can post a picture if you guys help. If you want to see a video of the costume I am trying to recreate see below.
    http://www.youtube.com/watch?v=SG_3R9BoVvg
    I need help finding the best way to do this. I know there are a couple of options like EL wire or LEDs. I think LED would be better, thus I am looking to recreate a chasing effect using LED light strips. I know there are alot of premade kits that can do over 80 different effects but I only need one simple light "traveling" through the strip. Like in the video below at 1:00 minute but only a single color.
    http://www.youtube.com/watch?v=2zSkkaif4Kk
    As another option could I be able to change it from one single color to a different color keeping the same chasing pattern. This is why I am considereing RGB lights instead of regular LEDs but I want this to be as affordable as possible.
    If you have any suggestions or ideas please let me know. I appreaciate all help.
    Thanks in advance
  2. Markd77
    Sep 7, 2009
    2,803
    594
  3. Coopette
    Sep 21, 2012
    Is there any way to make the circuit light weight and portable? with all the wires it looks really messy and I only have about a square 4 inches to hide the circuit
  4. Markd77
    Sep 7, 2009
    2,803
    594
    Soldered up on stripboard it could be around 4X8cm, 7X5cm or 6X6cm and about 1cm high.
  5. ScottWang
    Aug 23, 2012
    4,933
    777
    If you like to do so, can you write the program for MCU as 8051 or PIC, etc...?
    Or you want to use NE555 + CD4017x3 (or x 5) + Some RC to try it.
    Or NE555 + Ctrl Logic +CD4510x3 (or x5) + CD4028 x3 (or x5) + Some RC to try it.
    Or NE555 + Ctrl Logic +CD4516x3 (or x5) + 74LS154 x3 (or x5) + Some RC to try it.
    CD4017 datasheet, Decade Counter/Divider with 10 Decoded Outputs
    http://www.datasheetcatalog.org/datasheets/90/108738_DS.pdf
    CD4510(BCD)/CD4516(Binary) datasheet, Up/Down counter.
    http://www.datasheetcatalog.org/datasheets/320/109577_DS.pdf
    74LS154 datasheet, 4 to 16 decoder, Output Lo.
    http://www.datasheetcatalog.org/datasheets/70/232348_DS.pdf
    CD4028 datasheet, BCD to 10 decoder, Output Hi.
    http://www.datasheetcatalog.org/datasheets/228/108936_DS.pdf
  6. cork_ie
    Member
    Oct 8, 2011
    348
    58
  7. BMorse
    Sep 26, 2009
    2,675
    234
  8. BSomer
    Member
    Dec 28, 2011
    433
    106
    Another alternative to the conventional wiring methods would be something referred to as e-textiles. There are many different possibilities with this stuff. Micro-controllers, LEDs, batteries, whatever...
