Thanks again guys!!!!
Here is the first one!!
Nice.Thanks again guys!!!!
Very nice indeed.Thanks again guys!!!!
I always have fence post problems...Re # 87: Looks like there is no gap between 10 & 1 ?
I started with a 4514 , 4 line in to 1 of 16 out driven with a binary counter programed for a count of 15.
As stated above hard wire OR stages 1, 4,5,6,7 10, 11, 12, gap, gap, when 15 is reached counter reset to stage 1. Output of OR fed to 555 or a pulse stretcher to give flash a 30 % duty cycle. It's a start at least.
Another thought: Use 4060 for clock & binary counter.
On the other hand, spectators might get bored with the described flash rate - even a purist. The purist might like that it is correct until they demonstrate the 143 pattern and see how bored the spectator is.Was not expecting the 15.5 sec. gap but might add a 555 to fill the gap. My original thought might basically still be workable. Adjust clock so 5 sec. space is 5 sec & just fudge flash- off time slightly. Will delay further work until we hear from the Chief. Will need to rearrange the OR ing.View attachment 97150
Hola MarcI might have missed it, but is there any reference as to how mariners determined their azimuth by timing the light house flashes. I understand that by timing the time between the flashes and the beam direction you can determine your azimuth.
15 seconds is a long time. I made a device for an artist, who specified a 15 second pause time. IMHO, the pause was way too longOn the other hand, spectators might get bored with the described flash rate - even a purist. The purist might like that it is correct until they demonstrate the 143 pattern and see how bored the spectator is
I was in the USN Electronics "A" school at Memphis, Tenn in the 1960's and in the class describing the TACAN system, the instructor used a light house to describe how the system worked. A omnidirectional light flashes each time the beam is pointing north. By timing the difference between the light and the beam, you could determine your direction (I believe the technical term is Azimuth). I never really bothered to confirm if there were some lighthouses that did this. Your post revived this question for me.The azimuth is an horizontal angle measured with reference to the North. If you take a bearing to a certain buoy or lighthouse that you cannot identify, that azimuth is prety much useless
How small a circuit board? Would the battery need to be changed often?Shipmates, I am buildind working lighthouses in a bottle. They are selling great however I want to kick it up a notch. Lighthouses flash a varios rates and colors. Example: Ten Pound Island Light flashes red 3 seconds on and three seconds off. Boston light flashes white every 10 seconds. I need a circuit 3 vilts and ultra small that I can adjust the flash rate. Is this doable? I can etch my own boards. Any help would be appreciated.
Thread starter | Similar threads | Forum | Replies | Date |
Solar Lighthouse With 6 Leds | General Electronics Chat | 9 | ||
My Lighthouse Project | General Electronics Chat | 20 | ||
Off Topic: How to Float a Lighthouse? | General Electronics Chat | 44 | ||
Another lighthouse, inspired by " torpedo chief" | General Electronics Chat | 4 | ||
S | model lighthouse beacon light | General Electronics Chat | 11 |
