Hey all,
I'm having trouble with this homework problem from my digital logic class.
A low voltage lighting system is to use a binary logic control for a particular light located at the intersection of T-shaped hallway. There is a switch for this light at each of the three end points of the T. These switches have binary outputs 0 and 1 depending on their position and are named X1,X2,X3. The light is controlled by an amplifier with an input Z. When Z is 1 the light is ON and when 0 the light is OFF. You are to design a logic circuit Z = F(X1,X2,X3) so that if any of the switches is changed the light will change.
I would love to show you all the progress I have made, but I can't even figure out where to start. If someone could just point me in the right direction that would be fantastic.
Cheers
Cheers
