LIGHT SENSOR USING LDR AND TRANSISTOR...need help asap.
Discussion in 'Homework Help' started by Mihir1998, Jan 24, 2016.
  1. Mihir1998
    Jan 24, 2016
    7
    I've made a circuit as attached and it is working. No problems with that...but I'm unable to understand the exact flow of current and electons and the role of each component in the circuit...please help me out...i need to know everything before presentation which is on 28th Jan!!
  2. atferrari
    Jan 6, 2004
    2,672
    785
    Do not be lazy Mihir; put a multimeter in series with every part of the circuit and measure current while noting the polarity.
    Make sure of two things:
    that you keep the polarity of your probes consistent for all the measurements,
    that you test the circuit in two well defined conditions of that LDR.
    That could take few minutes and you could have a few hours of good sleep before the 28th, I guess.
  3. Mihir1998
    Jan 24, 2016
    7
    But I want to know the purpose of all the components....i do have a rough idea bt need some details...and also the working of transistor...
  4. atferrari
    Jan 6, 2004
    2,672
    785
    Measure all currents first and note polarities. That you can do alone.
  5. Mihir1998
    Jan 24, 2016
    7
    Alrite...den??
  6. atferrari
    Jan 6, 2004
    2,672
    785
    No idea what you are saying here.
    I give up. Buena suerte.
  7. Jony130
    Feb 17, 2009
    3,993
    1,116
    The BJT in this circuit acting as "switch". 330 ohms resistor limits (sets) the LED current. 220k ohms resistor together with LDR form a light dependent voltage divider. The resistance of a LDR decreases when the light intensity increases. So the output of the voltage divider decreases when the light intensity increases. And this will tur-off the BJT.
    Mihir1998 likes this.
  8. Mihir1998
    Jan 24, 2016
    7
    Thank u so very much jony!!!
  9. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Tell us what the ideas are, then we can help further (but not do your homework for you).
  10. Mihir1998
    Jan 24, 2016
    7
    Its not my homework...it's my project...
  11. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I moved your thread. It looks like a school project.
    You will learn more by examening the ciruit and find out yourself how it works.
    That way you can make your presentation more successfull.
    If there are any questions during the presention and you got the explanation from someone else,
    how would you react on the questions.
    Bertus
  12. Mihir1998
    Jan 24, 2016
    7
    Alrite...thank you bertus....I'll try tomorrow...if I still have some doubts then I will ask!!
  13. Mihir1998
    Jan 24, 2016
    7
    My project is use of an ldr for automatic light control...these are some pics...now I just need a clear idea of how the circuit works...and what exactly changes occur when the ldr is covered so that the led gets switched on!
