Light Sensor circuit not sensitive enough in dark room
Discussion in 'The Projects Forum' started by paddyhughes086, Mar 1, 2016.
  1. paddyhughes086
    Thread Starter Active Member
    Jan 30, 2011
    48
    Hi
    I have a Light circuit that works perfectly out doors were there is a big change between Light and Dark.
    I have built a second circuit for indoors to turn on a LED lamp at night and go off in the day but the room just doesn't get bright enough in the day for the LDR to pick up the change and turn off the LED.
    I am just wondering if I change the potentiometer to a 100k would this help. Or should I change the 100R resistor
  2. ericgibbs
    Jan 29, 2010
    2,595
    393
    hi paddy,
    You could try increasing the value of the 100R to say 10K.
    E
  3. Dodgydave
    Jun 22, 2012
    5,154
    770
    Ldr are useless for sensitive light, better to use a photo diode like TEPT5700, BPW34,
    Ideally get an ohm metre ,and measure the resistance of the ldr in the darkroom in different places, that will give you an idea of its resistance increase, then you can make the pot value to suit.
  4. TheButtonThief
    Feb 26, 2011
    219
    38
    Have you thought about the feedback loop?
    Maybe the reason why the circuit isn't switching the light off when the sun rises, is because the room is lit by the light >.<
  5. twohats
    Oct 28, 2015
    10
    Similar answer to Eric's.
    Remove the 100R and fit a temporary potentiometer. Adjust to suit switch ON and switch OFF.
    Then fit a suitable fixed resistor.
  6. paddyhughes086
    Jan 30, 2011
    48
    Sorry for the slow reply I was sick. Thanks everybody for the quick reply much appreciated .
    I will give it a go.
    Would the TEPT5700, BPW34, work in my circuit or would I need to build a new circuit
    Originally I did this this but I put the LDR on fly leads and removed it from my light source.
    Will give this a go
