Light sensing A or B switch
Discussion in 'The Projects Forum' started by MercilessMike, May 31, 2013.
  1. MercilessMike
    May 31, 2013
    I've racked my brain to come up with a simple 12VDC circuit to determine which strand of LED ribbon to turn on.
    Here's the plan:
    When here is ambient light (day time) and I open a door (reed switch) the High Output LED strand is turned on.
    When there is low light and door is opened, the red strand is turned on.
    I see using a photo resistor circuit, but the OR gate logic eludes me.
    Thank you for your time.
  2. LDC3
    Apr 27, 2013
    920
    160
    You want to use an AND gate, not an OR gate.
    1) Bright AND Door Opens
    2) Dim AND Door Opens
    MercilessMike likes this.
  3. MercilessMike
    May 31, 2013
    My initial idea was the reed switch act as a power switch for the circuit since it will be running of SLA batteries. I could add in a charging system to the SLA's from a solar panel.
  4. LDC3
    Apr 27, 2013
    920
    160
    You can still use the door open to power the whole system. Your conditions then become a choice of
    1) Bright
    2) Dim
    True, it is now a choice of 1 or 2, but you will see that it is more like 1 or not 1. So your conditions are simpler than you thought.
