Thank you Albert, it worked as you described. I will start to play with this until I get my result. Again, my heartfelt thanks.
The first difference that strikes me is in the config file - MCLR and Oscillator sections are different...Thank you Albert, it worked as you described. I will start to play with this until I get my result. Again, my heartfelt thanks.
The problem was getting at all to show on the display.FWIW:
With multiplexing, you have to turn the digit select completely off, then set the segments and turn on the digit select to eliminate ghosting. It's called "inter-digit blanking".
That's right.You have showed me that my wiring were correct but not the code for the light meter.
