Light Meter. How to Make an Proper Readout?
Discussion in 'The Projects Forum' started by MCU88, Mar 15, 2015.
  1. MCU88
    Mar 12, 2015
    360
    35
    Hello...
    I have made an project that has an LDR and ten LEDs that respond accordingly to the level of light that the LDR sees. Q: How do I add some numbers, a scale to the LEDs so that they have an meaningful readout?
  2. DickCappels
    Aug 21, 2008
    2,777
    674
    If you want to make something calibrated and that works with different light sources you would need a filter or set of filters to correct the response of the LDR to have a photopic response. This is approximately the same response as the "green" receptors in our eyes. An expensive solution.
    https://en.wikipedia.org/wiki/Photopic_vision
    If you consistently use it with the same kind or light (for example, same color temperature florescent or incandescent) then you can simply place a diffuser over the LDR (a ping pong ball cut in half works nicely) and then put it on the desk side-by-side with a borrowed illuminance meter (sometimes called a "Lux meter"), which is calibrated in Lux (for the originator of the until, Harrold Luxemberg) and calibrate your instrument for different amounts of incident light.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  4. MCU88
    Mar 12, 2015
    360
    35
    Sweet. So ...
    a. Ping pong ball cut in half
    b. Readout in Lux
    c. Calibrate to meter
    Cheers!
  5. MCU88
    Mar 12, 2015
    360
    35
    How badly not linear? I mean like the rest of them it is an 'toy' worth 5-dollars.
    Other options for sensors instead of the LDR?
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  7. MCU88
    Mar 12, 2015
    360
    35
    That's not too bad. A 45 degree line would denote 100% linear.
    I'll buy an lux meter and see if I can get away with it.
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I have added some alternative sensors to mo other post.
    Bertus
  9. MCU88
    Mar 12, 2015
    360
    35
    Thanx Bertus. That's perfect ;)
