light intensity and distance of color sensor
Discussion in 'The Projects Forum' started by thavamaran, Mar 3, 2009.
  1. thavamaran
    Thread Starter Active Member
    Feb 21, 2008
    67
    Hi, im Thavamaran and currently in final year of my degree, so im using TCS230, its a CMOS color sensor whereby im doing various types of test. TCS230 output is frequency and its digital. so i was doing a test recently whereby i place my sensor about +-5cm from a surface, which the surface consists of a particular color paper.
    So from 5cm when i slowly decrease to 4 cm ,3 cm and so on till i stick my sensor to the paper, the output frequency was slowly decreasing when the distance decrease. and when i increase my distance from 5cm, like say 6 cm and onwards, the frequency output increase.
    Can i know why its characteristic is like that? what is the relationship between light intensity and distance?
    PS: the illumination for the sensor was the fluorescent light in my lab, no external illumination.
  2. KMoffett
    Dec 19, 2007
    2,586
    234
    Per the data sheet:
    As you move the sensor closer the lighted surface appears brighter to the sensor. Think about the "inverse square law" of radiation.
    Ken
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. thavamaran
    Feb 21, 2008
    67
    Hey KMoffett, im sorry for bothering you, but i dont really know what is inverse square law of radiation, so can you explain to me in a least detailed way.
    beenthere, thanks for the link, i went through it.
    Thanks guys.
  5. KMoffett
    Dec 19, 2007
    2,586
    234
    Google is always my friend and yours:
    http://en.wikipedia.org/wiki/Inverse_square_law
    Basically if you double the distance between the sensor and the light source (your colored paper), the intensity of the light will be reduced to 1/4th the initial intensity...1/(2x2). If you moved it three times the original distance, the sensed intensity would be only 1/9th the original intensity...1/(3x3). If you moved the sensor to only 1/2 the original distance the sensed intensity would be 4 times the original...1/(0.5x0.5).
    Ken
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
