Light gates and Pic Axe chips.
Discussion in 'The Projects Forum' started by Wadderz, Jan 22, 2010.
  1. Wadderz
    Jan 22, 2010
    8
    I am just beginning a project that is going to use two light gates in order to determine whether a car is in a car wash or not, if a second enters while one is in there an alarm system will be set off using a pic axe chip, this pic axe chip also controls the traffic lights for this project. Can anyone give me a circuit diagram or explain a way for me to use the pic axe chip in this way?
    Thank you
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you can draw a diagram showing the locations of the sensors and a flow chart that charts to way the light and sensors work, you may solve the problem yourself. We need that to see if your ideas are reasonable.
  3. Wadderz
    Jan 22, 2010
    8
    Thanks for your input
  4. Wadderz
    Jan 22, 2010
    8
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I meant a diagram of the physical layout, with locations of the sensors and so on indicated.
  6. Wadderz
    Jan 22, 2010
    8
    Oh fair enough, i apologise
