Light Dimmer 2x 12V/60W
Discussion in 'The Projects Forum' started by MadMike99, Feb 9, 2015.
  1. MadMike99
    Feb 9, 2015
    Good evening everydoby. I want to make a light dimmer, but I've got some problems with it. I need to dim two light bulbs 12V/60W each. I was trying to do it with an LM358 but the power loss on the last transistor would be like 120W (12V per bulb/ current 10A). Can someone help me to create a scheme? I would like to make it and try it out. I want to mention that I am a beginner. I've attached my first project, but as I said there would be a big power loss on the last transistor. I have read about PWM but how will it work with two light bulbs that need 120W?
  2. Dodgydave
    Jun 22, 2012
    5,142
    768
  3. MadMike99
    Feb 9, 2015
    So as its written there I should only choose another MOSFET according to my needs (one that can carry 10A) and instead of the motor put two parallel located light bulbs, am I right? I forgot to add, that English is not my native language, so sorry for all mistakes that I have made.
  4. Dodgydave
    Jun 22, 2012
    5,142
    768
    Yes replace the motor with the parallel bulbs, you may need an heatsink for the mosfet.
  5. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    If using AC why not use a Triac control much lower component count than DC & PWM.
    Max.
