Hello, I am quite a beginner in electronics now, I used to do some projects about 10 years ago, but I am very rusty now. I am in need for help to design a device for a research project.
I am monitoring the activity of certain insects during morning hours and wanted to use video recording in the field so that I can sample from different places in a single morning and later spend hours watching the videos and recording the activity of these insects in the "comfort" of the lab.
I was thinking on getting a usb mini dvr pinhole cameras, and connect it to a "easy" light-activated relay (like the one on this page: http://www.sentex.ca/~mec1995/circ/actrelay.htm) so that when the sunrises, the relay turns on the camera. I got this idea from a kipkay video on youtube (http://www.youtube.com/watch?v=YWjer8Fhzh0). Now, I would also like to know how easy you think it is to add a timer circuit to the relay so that after 30min-1hr recording the relay shuts off the camera and stays off for the rest of the day (not responding to light), but then everything is reset during the night so that another hour can be recorded on the next day.
The reason for the reset function is to avoid to go to the field everyday to download the videos. I have seen mini dvrs with 8GB memory, as long as the battery does not run out and assuming 30 min - 1h videos, that would be enough for checking the cameras only once every three days. Also I would like to keep everything at low voltages so that the device can work only with batteries.
Please do not spend too much time thinking about this, I just wanted to know an expert opinion on whether this kind of device is feasible and relatively "easy" to build. This is an ongoing experiment and may not have time to build complicate designs, but if you know a relatively easy way to design a circuit with this functions that would be a great help.
Thank you very much in advance.
