This lift station is going to be controlled by a master control relay switch, 2 hand off auto switches, 4 discrete flow switches(lead, lag, off, high level alarm). These floats are going to control 2 pump motors. Each motor will have 2 red lights for running and 2 green lights for stopped. The lead motor can typically keep up with the water influent flow, an alternating control circuit need to be implemented so that both motors maintain about the same run time. Simple enough but the catch is that this has to be done without using a alternating relay. That is where I am lost any feedback would help. Thanks.
-zip
-zip
