Li-ion vs. Ni-MH battery
Discussion in 'General Electronics Chat' started by emilpdan, Oct 24, 2012.
  1. emilpdan
    Oct 24, 2012
    Would i be able to replace a 1100mAh, 3.6V, Li-ion with a 900 mAh, BMC-3, 3.6V, Ni-MH battery in a Nokia 3310?
    Would there eg. be problems with charging with the "old" charger (for the Ni-MH)?
  2. timescope
    Member
    Dec 14, 2011
    298
    44
    This is not a good idea because the charging requirements of Li-ion and Ni-MH are different : Li-ion is constant voltage and Ni-MH is constant current.
    www.ti.com/lit/an/snva557/snva557.pdf
    Timescope
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The charger circuit is inside the phone, not inside the "charger". The "charger" is simply a power supply for the charger circuit inside the phone.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    I've never seen a consumer product where you can swap in Li-Ion for Ni-MH. The charging hardware would have to be very complex and be able to "recognize" the battery type based on memory devices in the battery pack and then accomodate it by changing the charging algorithms.
    When I worked in the IC industry, some makers talked about maybe doing that but the cost was prohibitive. I've never seen a consumer product with such a charger built in.
  5. emilpdan
    Oct 24, 2012
    Thanks for the great answers!!! appreciate it.
