Li-ion constant current method
Discussion in 'General Electronics Chat' started by billybobjoe, Mar 10, 2009.
  1. billybobjoe
    Mar 10, 2009
    Hi
    I am using this circuit attached which is fairly common method of getting a constant current of approx 1A to charge Li-ion batteries. however it just seems to be shorting out when i try attach the batteries. any idea why or how do i attach the batteries properly.
    (the attachment shows a load where my batteries should be. Resistor is the same - which should provide 1A)
    Or is there another way of getting a reliable constant current with Lm317?
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    The input voltage must be at least 3.3V more than the output voltage and be able to supply 1A.
    The LM317 or LM117 will get too hot without a heatsink and will shut down.
    If a Lithium battery cell is charged higher than 4.2V then it will probably catch on fire.
    The circuit has nothing to limit the charging voltage.
  3. billybobjoe
    Mar 10, 2009
    i have a uC that will take care of switching off the charger when 4.2 volts are reached.
    what improvments should be made?
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Go online to The Battery University (look in Google). They have a graph that shows a lithium battery cell is about 70% fully charged when its voltage reaches 4.2V. The cell is fully charged much later when its current has dropped to about 3% of its recommended charging current.
  5. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
