Li-ion Battery Protection
Discussion in 'Power Electronics' started by Dr.killjoy, Jul 18, 2016.
  1. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    I have been working on a small li-ion charging circuit for my 18650 cells .. But I wanted a low voltage indicator but figured I would better off with a battery protection circuit.. I know there are alot of parts out there for this job but I don't want to buy anything premade.. So I am looking for a IC/Parts and would like some help or suggestion on attempting this ??
  2. BobTPH
    Jun 5, 2013
    806
    121
    18650 cells with the protection built in are available, in fact I think they are the more common type.
    Bob
  3. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    Thanks and I am not looking to buy new cell because I already have a nice stash but just unprotected cells...
  4. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Home-brew is commendable, but in the interests of safety it might be wiser on this occasion to use available dedicated protection circuits.
    Dr.killjoy likes this.
  5. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Maxim do a small selection of voltage monitor chips.
  6. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    Thanks for the concern. I understand what ur saying but I really need to learn how to build these circuits and why & how they work.. Plus I have been learning they most stuff made in china sucks and doesn't always work or even right..
    Thanks I will have to check them out..
  7. electrophile
    Member
    Aug 30, 2013
    100
    TI has a nice selection of devices for this.
  8. ian field
    Oct 27, 2012
    4,447
    791
    For several years now, I've been using a TL431 based shunt regulator for my E-cigarette.
    So far - I haven't bothered with low voltage shutdown, but the E-cig uses a logic level MOSFET controlled by a low rated tact switch pushbutton. That is a UVLO of sorts when the cell voltage no longer exceeds VGSthr.
  9. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    My plan was to use a proper timed charge ic to charge the li-ion. I realied that I needed some kind of low voltage protection to keep the cell healthy.. Your circuit seems pretty cool and will have too look into it .. Would you happen to have the schematic ??
  10. ian field
    Oct 27, 2012
    4,447
    791
    It was published in Elektor a few years back - I sold them the rights to it.
    There's an updated version recently sent, they haven't contacted me yet.
    The shunt regulator must handle all the charging current when the cell reaches the specified terminal voltage - the basic TL431 can sink 100mA.
    You can boost the current capability by making a hybrid Sziklai pair with the TL431 and a PNP power transistor.
