Li-Ion batteries PCB wiring issues
Discussion in 'General Electronics Chat' started by Michael67000, Mar 7, 2016.
  1. Michael67000
    Mar 7, 2016
    6
    I've recently bought several PCB's intended to wire on it 3 Li-Ion batteries in serial and to protect them when you charge them. Here is the product :
    http://fr.aliexpress.com/item/4A-6A...m-Battery/32386175340.html?detailNewVersion=1
    Unfortunately, the ones I got are different from the pictures as you can see on the photo below. I've wired my batteries on it and I got first 12V at the output, but I couldn't recharge the batteries and after a few hours, my batteries ran down although I haven't wire anything on it.
    How is this possible ? Did I wire them wrong ?
    I've noticed that my positive output is the one written P- and not P+
    Thanks,
  2. blocco a spirale
    Jun 18, 2008
    1,463
    372
    All the cells connected incorrectly, according to the PCB.
  3. Michael67000
    Mar 7, 2016
    6
    I connected them in the opposite way first (every + and - were changed), but I had 0 V at my output and the seller told me to connect them this way... But now that I have other issues, he told me "he does not know much about his product"
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    If a Li battery has reversed its polarity it's probably damaged beyond repair and unsafe to try to recharge it.
  5. blocco a spirale
    Jun 18, 2008
    1,463
    372
    I suspect that the PCB labels are most likely to be correct.
  6. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    You have wired them wrong. You might be able to salvage something, but then again maybe nothing. In cases like this, I would recommend seeking the data sheets for your ICs to see what their operational requirements are, then assess their relationship in the overall circuit.
  7. mcgyvr
    Oct 15, 2009
    4,793
    976
    Or don't buy undocumented cheap junk from China :)
  8. Michael67000
    Mar 7, 2016
    6
    Yes I also think the labels were inverted... and the seller don't have any data sheets on it. I think I'll ask him to refund me.
    Do you guys think I can skip this pcb's in my project, and just solder the 3 batteries in serial with a female DC power jack to charge them ?
  9. mcgyvr
    Oct 15, 2009
    4,793
    976
    Absolutely not..
    Li-ions MUST be charged properly..
  10. crutschow
    Mar 14, 2008
    13,523
    3,390
    If you do, be sure you have the fire department number on speed dial. :eek:
  11. Michael67000
    Mar 7, 2016
    6
    Just wanted to be 100% sure, that's what I thought.
    Huge thanks to you guys for your answers and being so quick!
  12. pebe
    Oct 11, 2004
    628
    I have an identical PCB. It works well and is certainly not 'Chinese junk'.
    You have connected all the batteries the wrong way round.. Each of the battery connections has a built-in FET to protect for over-current so it is possible you may have not caused damage to the board, but you may have over-discharged the batteries. . Reverse all battery connections and check the voltage at P+ and P-. If you have volts there all may be OK.
    Note that you need to limit the charging current - the PCB does not control that.
    Edit: Check that none of your batteries has a low output voltage That would stop the PCB from working because it cuts off the output if the output of any cell falls below approx 2.5V
  13. Michael67000
    Mar 7, 2016
    6
    OK, I've ordered a charger to recharge my batteries. I'll retry asap, but before connecting them this way, I tried in the opposite way (every + and - were interchanged) and I didn't have any voltage at P+ and P-, but maybe one of my batteries were down and that's why it would have stopped the PCB working.
  14. Michael67000
    Mar 7, 2016
    6
    I've finally got my charger and I've continued the tests. I've wired my fully-charged batteries upside-down compared to the photo, I have about 12V between B+ and B- but nothing between P+ and P- which is supposed to be the appropriate output. Would someone have any idea please ?
  15. Dodgydave
    Jun 22, 2012
    5,167
    777
    Its the pcb thats faulty, i had exactly the same problem with those two pcbs, replaced it with this board and it now works, it charges and discharges perfectly.
    Note you have to connect the batteries correctly, then apply the charger, and then remove the charger and the voltage appears at the p+/- pins.
