MaxHeadRoom
- Joined Jul 18, 2013
- 28,702
Those Outrunner motors are pretty trouble free I found it is usually the 3ph controller that goes.
Max.
Max.
Do you still have the LG washing machine control board with an open fuse? The bare board appears to be the same as the one in my LG WM3988HWA combo-washer dryer, except that the dryer-related component positions are not populated. If you were unable to get the board going, I would be interested in buying if from the owner for experimental/spare parts use.I have this control board from an LG washing machine and the main fuse is open...
Good luck with the repairs. I may be able to help you with that.we may be removing the fuse and replacing it and then finding the cause on the machine.
Just dug it out of the silicone. If anyone needs to know it is a 15 AMP 250VI think I have the same LG Board 6871ER1062D and was wondering if anyone knows the amperage rating of the fuse that is potted on that board. I had a motor that was hard to spin due to a drum issue and the fuse blew due to excessive amp draw. I now have the drum and motor spinning freely and need to replace the fuse but cant read the amp rating.
There are usually two to five additional letters/numbers in the fuse to let you know the physical dimensions, fast or slow blow, etc.Just dug it out of the silicone. If anyone needs to know it is a 15 AMP 250V
I am having the exact same problem and i would LOVE to know how it went! Did you replace the fuse?Just dug it out of the silicone. If anyone needs to know it is a 15 AMP 250V
Could you help me with my electrolyte capacitor missing on my control board for a GE washing washingUnusual for C.C. to be 1/2" thick?
It is not toxic once set, unless you light it!
The remover gives off a little fumes or odour.
You would not need to remove it all though.
Max.
Photos and more detail, please.Could you help me with my electrolyte capacitor missing on my control board for a GE washing washing
Figured I'd update incase anyone else wanted to see pics on how this can be achieved. Do this at your own risk.
I didn't have time to buy/wait for a pcb mount cartridge fuse holder, so I ended up just fabricating its own terminals/legs with some 18ga copper solid wire . Wrapping it tightly around the fuse then solder.
I did end up having to cut a small access hole on the backside of the board cradle. Heated a razor Blade up and slowly went along allowing it to "sink through" the plastic cradle.
I set the height of the fuse a little higher than before for ease of servicing in the future.
I then "stitched" the access hole patch back across with the iron.
Actually wasn't too bad of a job.. And the potting compound wasnt too difficult to remove either... Just take your time and don't go crazy. Hint... Similar method to how I cut the access hole. Just be mindful of the depth..
Not sure why LG didn't incorporate an auto resetting thermal fuse for protection instead of this "non replaceable" cartridge type.
you have a failed water pump relay. this occurred on two of the LG top loading washers.. The Wt1101 and the wt5001. They both have different pcb's but same problem..Hello my LG fully automatic washing machine shows OE error, i have cleaned all the drain motor etc, when we switch on the tub just shakes little and it continues even if we press the power switch on the machine , can anyon etell me what will be the fault like?
