LG monitor power problem.
Discussion in 'General Electronics Chat' started by Αντώνης Τερζής, Aug 22, 2015.
  1. Αντώνης Τερζής
    Aug 22, 2015
    11
    Hey there AAC guys, this is my first post to your great forum.
    So here is my problem.I own a LG 23MA53D tv that I use as a computer monitor. The power cable was a little bit short so I made an extension and it worked like a charm for about a year. So yesterday while I was cleaning somehow the diy power supply extension I had made shorted and a little spark came of(my tv was turned off) after that I tried to turn on my tv but as expected nothing happened.My tv doesn't have an internal transformer. It has an external power brick so I tried to open it and look for any blown capacitors but with no luck. Right now I am ready to cry so I need your help to this problem . thanks in advance!
  2. absf
    Dec 29, 2010
    1,493
    374
    What is that external power brick for?
    All my TV are plugged directly to the mains sockets...
    Allen
  3. shteii01
    Feb 19, 2010
    3,500
    511
    absf likes this.
  4. ScottWang
    Aug 23, 2012
    4,925
    777
    Take some clear photos will be help for your problem.
  5. bwilliams60
    Nov 18, 2012
    734
    94
    Have you measured the output of your "power brick"? Lets figure out if its that or the monitor first. If it is in the monitor, pull the back off and post pictures of the boards.
  6. Αντώνης Τερζής
    Aug 22, 2015
    11
    Thanks for your reply! I'll try to upload some photos of the power brick and the tv's main board.
  7. Αντώνης Τερζής
    Aug 22, 2015
    11
    I thought about by I don't have a spare polymeter right now and it is kinda difficult to find one. I'll post some photos tomorrow morning of the board.Thanks!
  8. absf
    Dec 29, 2010
    1,493
    374
    Ah... that "brick". It's the same as the one I use on my ASUS laptop.
    As you have already opened it up and found no fuse was blown. Do you have a multimeter so that you can measure if there is anything shorted? Most probably an electrolytic cap or MOSFETs.
    Allen
  9. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    I second (or third) checking the power brick. Even if the TV was on, it would have been the brick that was likely to be damaged by a short.
  10. Αντώνης Τερζής
    Aug 22, 2015
    11
    Well, I tried to use my laptops but the output wasn't enough to power the monitor. I could find a multimeter but I have no knowledge of using one. I will seek for tutorials in the internet. So you say that I need to find a multimeter and test the capacitor's capacitances?
  11. Αντώνης Τερζής
    Aug 22, 2015
    11
    Do you know any possible way to check of the power brick is ok?
  12. Αντώνης Τερζής
    Aug 22, 2015
    11
    So here is a quick photo. I am sure you can't understand much from this photo. The brick has three capacitors. You can clearly see the two and the third hidding in the corner.
  13. R!f@@
    Apr 2, 2009
    8,785
    771
    can you take voltage measurements
  14. Αντώνης Τερζής
    Aug 22, 2015
    11
    I wish
    I wish I could but I don't have a multimeter available
  15. R!f@@
    Apr 2, 2009
    8,785
    771
    So what makes you think you can troubleshoot and fix it?
  16. dl324
    Mar 30, 2015
    3,376
    651
    Measure the output of the power adapter with a voltmeter. If you're uncertain of what you're doing, you should find someone who does. Even if the adapter is damaged, you could still expose yourself to dangerous voltages if you have it opened.
  17. ian field
    Oct 27, 2012
    4,447
    791
    Those power bricks invariably have over current shutdown, and are reasonably robust - but a sudden short can damage the secondary side rectifier.
    As always with SMPSU, you have to watch out whether the secondary rectifier is Shottky-barrier type, a fast silicon rectifier will over heat if used to replace a SB rectifier.
    Most monitors with power brick and a lot of laptops I've seen were 19V - I've never seen a TV with a power brick.
  18. R!f@@
    Apr 2, 2009
    8,785
    771
    There are TV's with power bricks.
    I have seen Sony using them.
  19. ian field
    Oct 27, 2012
    4,447
    791
    I didn't say there weren't any - just that I haven't seen one.
    It sort of alludes to the idea that I wouldn't know what voltage a TV brick puts out.
  20. Αντώνης Τερζής
    Aug 22, 2015
    11
    Thanks! The first thing I am going to do when I find a multimeter is this.
