LF357 dual op amp
kahafeez
Joined Dec 2, 2008
150
hi all, i need to know the dual op amp of the part number LF357..... like TL072 is the dual version of TL071..... just like that whats the dual version of LF357....
kahafeez
Joined Dec 2, 2008
150
ok thanks..... that was y i couldnt find the dual version..... anyways folks..... believe it or not i made the 450KHz sine wave oscillator(wein bridge) with TL072....... and it worked..... when i used LF357 that gave distortion..... may be there was some problem..... i dont know bt as TL072 is working fine for me i dont have any trouble anymore..... i tried making a TL072 450Khz oscillator before on a breadboard bt this time i tried on a PCB that worked.... yuppeeee!!!
Audioguru
Joined Dec 20, 2007
11,248
A TL07x runs into trouble when the output is higher than 100kHz.
An OPA134 single, OPA2134 dual or OPA4143 quad work well up to 250kHz at max output level or up to 1MHz at lower levels.
