LF Antenna Construction (125 to 134 kHz)
Discussion in 'Wireless & RF Design' started by mossman, Apr 8, 2013.
  1. mossman
    Aug 26, 2010
    131
    I am attempting to capture the radiated wave from a couple passive RFID tags, one which transmits at 125 kHz and the other at 134 kHz. I need to make a rudimentary AM antenna to detect these signals and view the modulation on an oscilloscope. I am currently using a signal generator and near field antenna probe to transmit a carrier to stimulate, bias, etc. the tag which takes the signal, modulates it, and re-transmits it. I need to capture this re-transmitted modulated signal and view it on a scope so I can decode the modulation. Any help would be greatly appreciated.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Are you serious about the frequency? It seems way to low to be practical. I say that because an efficient antenna at those frequencies is incredibly long and there is very little bandwidth for data transmission at those frequencies. Very slow CW on a waterfall display is about all you can manage.
  3. davebee
    Oct 22, 2008
    539
    46
    A plain old ferrite loopstick should work.
    I used to pick up LORAN transmissions at 100 kHz when working on circuits at my house. Even though the LORAN transmitters were several hundred miles away, it still was sometimes a struggle to keep the LORAN signal out of my breadboarded circuits. A few inches of wire at the input of an op-amp would pick up enough 100 kHz energy to show up on my scope.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
  5. davebee
    Oct 22, 2008
    539
    46
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Still no info on the available bandwidth utilized and how the messages are encoded and decoded.
  7. atferrari
    Jan 6, 2004
    2,674
    785
    Maybe the scope does not need it to show the signal... I guess.
  8. mossman
    Aug 26, 2010
    131
    There's a ferrite stick antenna in a cheap AM/FM radio I have at home. Would this be able to pick up the transmitted RFID signal? Would I need to remove some of the loops to tune it to the 134 kHz range?
  9. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
