Levitation!
Discussion in 'Off-Topic' started by Markd77, Nov 6, 2012.
  1. Markd77
    Thread Starter Senior Member
    Sep 7, 2009
    2,803
    594
    I've always wanted to try this so I ordered some Bismuth and cast it into a couple of coin shapes and now I can get nearly 1.5mm stable levitation, it can be improved a bit if I get a more powerful small magnet and it's a little higher if I put the bismuth cylinders above and below the magnet, but doesn't look as good.
    It's explained here:
    http://scitoys.com/scitoys/scitoys/magnets/suspension.html
    The little magnet is 3mm high and 3mm diameter.
      File size:
      58.6 KB
      96
    loosewire, BSomer, tshuck and 2 others like this.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    I would be interesting in more pictures.
    Sparky49 likes this.
  3. Sparky49
    Jul 16, 2011
    835
    417
    I like seeing what the 'pros' of the forum get up to with their projects. :)
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I built an electromagnetic levitator once. It held a paper clip covered in scotch tape beneath the coil at a distance of half a centimeter or so for well over a minute. I'll have to see if I can find the video.
    It used an infrared emitter and detector to sense the location of the paper clip, and to switch power to the coil on and off, according to its position.
    I've always enjoyed watching magnetic levitation work. Ever since I was a little kid, it's always amazed me. And even now that I know the science behind it, and that I've made it happen on my own work bench, it still fascinates me :D
    Nicely done Mark. I look forward to seeing a modified version!
    Regards
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    It puzzles me how many people confuse magnetic levitation with antigravity. I suspect they are the same crowd as overunity, no real understanding of the forces in nature.
    DerStrom8 likes this.
  6. tshuck
    Oct 18, 2012
    3,531
    675
    I too have been wanting to do this...
  7. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    BSomer likes this.
  8. Markd77
    Sep 7, 2009
    2,803
    594
    Don't worry I haven't lost my marbles, I know that gravity is unchanged. I imagine the diamagnetic effect is too weak to have any real uses, but it's fun to see.
    With Bismuth and the strongest lifting magnet I have (the black cube) it's only just strong enough for the levitation to work.
    Sorry about the bad photo, there is a good photo of someone else's on the link below.
  9. MvGulik
    Member
    Nov 3, 2011
    40
    9
    Nice and interesting read.
    That Magnetic Linear Accelerator (other page on OP web link) seems like a nice school project. Looks initially like magic, until you understand how it works.
    (Little circular Gaussian accelerator http://www.youtube.com/watch?v=LqKCblEluqM )
  10. Sparky49
    Jul 16, 2011
    835
    417
    Today in physics we made a massive capacitor out of two sheets of aluminium, each 50cm x 150cm, seperated by a bin bag. The intention was to make it deliberately arc, as we had done this before, but it clearly wasn't quite as cool.
    Anyway, we got to about 5kV and our teacher was moaning, because we had built it too well (what can I say, I like to do a good job! :D), but then it did arc, and what a din!
    Very impressive sparks too, holes in both plates and the diaelectric.
    A good reminder of the power of electricity!
  11. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Why didn't you just make a solid capacitor designed to NOT break down, and just put a static spark gap across the plates? It would have preserved the capacitor and it could be used for future demonstrations. Seems a lot more effective and efficient than intentionally destroying it :eek::p
  12. Sparky49
    Jul 16, 2011
    835
    417
    Ah, because big sparks are cool. So are the holes they leave!
    Besides, it cost no more than 10p, and it took two minutes to make, so why not? :D
  13. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Haha, seems legit. Glad you had that experience on purpose at least, unlike me :D:D:D
