I have two 100K Hz square waves which are being produced by a TL598 chip set up for a push pull configuration. The magnitude of the square waves are 12 volts peak to peak since the voltage source for the TL598 has to be 12 volts DC. However, I need to convert those square waves' magnitude to 5 volts peak to peak in order to feed them to a high voltage, high speed power mosfet driver (IR2181). Do any of you guys might have an idea of a level shifter that can convert a 12 to 5 volt peak to peak square wave. Please advise if any of you can help me. Thank you in advance
