Lester ferro-resonant charger?
Discussion in 'General Electronics Chat' started by MikeML, Dec 19, 2013.
  1. MikeML
    Thread Starter AAC Fanatic!
    Oct 2, 2009
    5,451
    1,066
    My neighbor's golf cart is showing signs of chronic undercharging of its flooded lead-acid deep-cycle batteries (uneven voltages between groups of cells, low capacity). It has 18 cells; nominally 36V. Under charge using the Lester 09611 charger, the batteries barely reach 38.0V (2.12V/cell), which is not enough to top them up. The end-of-charge voltage should be at least 45V (2.5V/cell). The charging current tapers to zero prematurely (too soon)
    The Lester charger is dirt simple. Here is the schematic. Big transformer, 115Vac primary, center-tapped secondary, two rectifiers with common cathodes which make the +; - taken from the c.t. i.e. full-wave rectifier. The tranny has an extra winding which is paralleled with an 6uF 660Vac AC capacitor, with no other connections. AFIK, it is some sort of crude ferro-resonant regulator.
    I have checked continuity, and everything appears good. Diodes good, fuse good, transformer windings all show continuity, no shorts between windings. The only thing that looks suspicious is that the resonating capacitor measures 2.94uF instead of the marked 6uF.
    Is this the reason why it is not charging the batteries? Not resonating properly? How does this regulate?
  2. inwo
    Nov 7, 2013
    2,435
    315
    Can't explain how it works, but experience tells me that's the problem.
    Common problem with chargers and also generators.
    I'll be watching for the explanation, myself.
    ps.
    That reminds me.
    Was going to post but thought better of it.
    I test most things for shorts with a variac.
    A similar charger that I had on the bench seemed to be shorted.
    Turns out that it tries so hard to regulate at lower voltages it looks like a short when slowly bringing up to voltage.
  3. GopherT
    Nov 23, 2012
    6,304
    4,027
    I would say it is likely the cap (or a bad cell in the battery)- that cap and tranny tap (inductor) resonate and allow the voltage to climb as current draw drops. It is kind of odd and it works - really old school with no active parts.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Not a bad cell as indicated by the ammeter on the charger, and by measuring battery voltages. The charging current tapers to zero before the batteries are charged. If there were an open cell, the battery terminal voltage would be high (it isn't). If there were a shorted cell, the charger current wouldn't taper. The charger tapers without getting the battery voltage high enough.
    The link above didn't resolve: Here are the specs:
      File size:
      154.8 KB
      25
  5. Tesla23
    May 10, 2009
    323
    67
    I knew nothing of ferroresonant chargers so I had a look around.
    A rough explanation of how it works is here:
    http://www.catalina-capri-25s.org/tech/Batterychg.pdf
    I guess if the cap loses it's value then the resonant circuit will be off tune and won't be driving the transformer to saturation, hence the output voltage will drop.
    inwo likes this.
  6. tcmtech
    Nov 4, 2013
    2,110
    1,750
    Replace the weak capacitor.
    On a ferroresonant type charger that capacitor sort of works as your peak voltage adjustment.
    Smaller value lower peak voltage. Larger Value higher peak voltage (up to a point.)
