length of a required stub
Discussion in 'General Electronics Chat' started by retired flyer, Aug 7, 2014.
  1. retired flyer
    Aug 3, 2014
    5
    In a transmission line I determined the length of the stub to be 2.81 inches. What would the length be if the stub were shorted? Thanks for the help.
    Regards,
    Walter
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    the same length, but high impedance instead of low. refering to 1/4 wave stub that is.
  3. retired flyer
    Aug 3, 2014
    5
    Thank you for answering my previous question. Maybe you have the answer to another question that I am having trouble finding an answer to. "A 150 ohm transmission line is terminated into an antenna with an unknown impedance. Power delivered to the antenna is 600 watts ; what is the SWR"
    Regards,
    Walter
  4. djsfantasi
    Apr 11, 2010
    2,900
    876
    Is this homework or a project?
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I think it is untoward to repost the identical question in another thread just because you didn't like the first answer. There is not enough information to answer your question. You need the impedance of the antenna or the reflected power. What's the matter with you?
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    150 ohm transmission line into unknown load? the swr depends on the load, without it or an swr meter inline, this question cannot be answered.
    retired flyer likes this.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    Assuming the stub is a matching "device" having the necessary complex impedance at the frequency of interest - to get the same stub impedance a shorted stub would need to be a quarter wavelength longer than an open stub.
  8. retired flyer
    Aug 3, 2014
    5
    There is nothing wrong with me. I just want more than one persons input to my question. What is the matter with you that you have to be rude?
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
