LEDs
hondabones
Joined Sep 29, 2009
123
Define what you want to do a little more carefully, colors of LEDs, quantity, that sort of thing. You must have a resistor, or an equivalent.
Red is a good color, each LED will drop around 2.5 volts. They can vary depending on the specs, so that would be useful, but for now I'll assume 2.5V Vf (forward dropping voltage).
If you have 12V (2 6V batteries in series) then you can have 4 of these leds per chain, each with it's own resistor. If the LEDs take 20ma (0.02A) then it goes something like this...
4 LEDs at 2.5V drop 10V
12V - 10V = 2V
To calculate a resistor for 20ma then
R = 2V/0.02A, or 100Ω. A ¼W resistor will work fine.
This is an illustration from the article I recommended you read. If you want to make sense of it, then follow up and read the article.
Bill,
I snagged this from a post you did earlier.
This is the basic idea of how to light all of the LEDs? It's that easy?
Anyone can reply. I'm not singling Bill out
Jim
hondabones
Joined Sep 29, 2009
123
I am in my 3rd Quarter at ITT for electronics. I just wanted to light all my LEDs in my toolbox. (just messing around) but I couldn't quite get it. Now that I seen this post by Bill I feel like an idiot. My only question is...
How do I get more current so the LEDs are brighter?
This is probably a dumb question too. lol.
If I raise the voltage the current increases. I don't want this. I will use only 12 V. If I lower resistance the current increases. This, however, will effect the voltage drop on the LEDs. I can't do that either. The choices of resistors is limited so I am forced to use:
4 x 5 rows (20 LEDs)
4 - 82 Ω Resistors
2 - 56 Ω and 27 Ω in series (don't have enough resistors to be consistent)
12 V industrial heavy-duty lantern battery
LED specs:
3mm Red
Vf = 2.6 V
If = 20 mA
Wendy
Joined Mar 24, 2008
23,415
I tend to focus on 20ma because that is a max for many makes. You can buy LEDs that use 1.4A, and there are or will be units that use even more current with corrisponding increase in brightness. Such units need heatsinked, since they generate over 3W in heat, but compared to light bulbs or fluorescent they still represent a major improvement in efficiencies. There are concepts just over the horizon that will be even better.
LEDs are pretty easy and cheap, which makes them fun. They also have some other characteristics that I find pretty useful, such as the Vf, which is a pretty good constant voltage I occasionally use for other jobs.
You will find the voltage drop on the LEDs doesn't decrease that much with a reduction in current, this is both a blessing and a curse. The max current rating is just that, a max. They can use less, and still be plenty bright. The amount of light generated is pretty nonlinear compared to current, which makes PWM a very good option for controlling LED brightness, since it is linear.
LEDs also have a long lifespan that will shorten considerably if you overdrive them. Less is usually better than more.
Audioguru
Joined Dec 20, 2007
11,248
Look at the datasheet for an LED to see the very small change in voltage that is caused by a change in current.
Here is the voltage/current graph of some ordinary red LEDs that I have. The max allowed continuous current is 40mA or 200mA peak. At 25mA they are very bright.
At 2mA the voltage is 1.6V.
At 10mA the voltage is 1.7V.
At 50mA the voltage is 2.0V.
At 200mA the voltage is 2.75V.
ELECTRONERD
Joined May 26, 2009
1,147
They also have LED drivers that provide a simple connection of series and parallel LEDs. I've seen drivers that will drive 60 20mA to 30mA LEDs.
Austin
