LEDs Wiring
Discussion in 'The Projects Forum' started by jeremyhaberman, Aug 7, 2013.
  1. jeremyhaberman
    Aug 7, 2013
    Hello everyone,
    I am build an overhead panel for my home cockpit and I need some help. I will have some DPST switches that will have one set of poles going to a usb interface board my my flight simulator to recognize the command (this part I understand). I want to wire a LED to the second set of poles. My confusion is that I want to have multiple LEDS all controlled separately (by their own on/off switch) but powered by one power supply, is it possible and how can I do it. I really need the help.
    :confused:
    Much Thanks,
    Jeremy Haberman
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    yes its simple.
    wire each led with its own current limiting resistor and done.
    jeremyhaberman likes this.
  3. tubeguy
    Nov 3, 2012
    1,157
    197
    If you need help on calculating current limiting resistors, please post your LED specs and LED power supply voltage.
  4. jeremyhaberman
    Aug 7, 2013
    I want to use 5 red LEDs at 2.2 v and 20mA, 5 Blue LEDs at 3.2v at 20mA, and 3 green LEDs at 3.2v at 20mA. I want to use a 5vdc 300mA power supply. Each LED will have is own toggle switch. What type of resistors do i need.
  5. mcgyvr
    Oct 15, 2009
    4,787
    973
    Resistor values are calculated as follows.
    R= (Vin-Vf)/A
    Where
    Vin is power supply voltage
    Vf = LED forward voltage drop
    A=led current in amps
    Then you need to calculate the wattage for the resistor where
    P=2 x (I^2 x R)
    Where P watts
    I = led current in amps
    R=resistance
    Example (for red LED)
    Resistance
    5-2.2 = 2.8
    2.8/.020 = 140 ohm resistor or slightly larger
    Wattage
    .02^2 = .0004
    .0004 x 140 = .056
    .056 x 2 = .112Watts (1/8W resistor)
    The times 2 is a "safety factor" to keep the resistor from running too hot.
    In general LED's do fine anywhere from 10ma to 20ma (more current the brighter they are)
    BUT once you start going over 20mA the lifespan is usually decreased.. So always shoot for no more than 20ma
  6. jeremyhaberman
    Aug 7, 2013
    Thanks, I like how instead of just telling me straight up which one to use yoU tell me how to calculate using the formula because I need to learn this stuff.
  7. mcgyvr
    Oct 15, 2009
    4,787
    973
    No problem..
    Have fun with your cockpit :D
