LEDs in series
Discussion in 'General Electronics Chat' started by vindicate, Sep 25, 2011.
Thread Status:
Not open for further replies.
  1. vindicate
    Thread Starter Active Member
    Jul 9, 2009
    158
    If I have an LED with 3V forward voltage. A 12V power supply, and 4 LEDS that I want to put in series.
    What size resistor do I use? If you do the normal calculations you wouldn't need any resistors, but is that right? How would you get the 20mA current needed?
  2. KJ6EAD
    Apr 30, 2011
    1,426
    363
    The forward voltage rating is an average, not a precise figure and the effective series resistance of an LED reduces as the temperature increases causing overcurrent. Just wire them in two series strings of 2 and waste a little energy in 300Ω resistors.
  3. #12
    Nov 30, 2010
    16,703
    7,338
    Entirely correct. The most common difficulty with people and LEDs is that they can not understand that the LED has no helpful resistance. It is a "breakover" device. Once the voltage breaks over the threshold, the LED can not protect itself from excessive current. You absolutely must "waste" some voltage on a current limiting resistor or the only thing you will accomplish is smoke.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    All of which is correct, so if you have 3.0V Vf and 12V you should only have X3 LEDs, which adds up to 9V, and the other 3V is used by a resistor to set the current. It drives beginners crazy, but there it is.
  5. Adjuster
    Dec 26, 2010
    2,147
    300
    To be sure of good results, you need to know the possible range of the "3V" LED forward voltage, and that of the "12V" supply. The LEDs will vary a bit between individuals, and with temperature, and the supply voltage may vary a good deal, especially with a battery supply.
    Suppose you choose a resistor to set the LED current to a safe value with maximum battery voltage and minimum LED voltages.
    Now, check the LED current with that same resistor, but minimum battery voltage and maximum LED voltages (a little over-pessimistic, as the current will be less): is the current too low? Then you have to use fewer LEDs, or possibly consider a more complex active drive circuit.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    3V is a pretty good margin. Lower voltage, such as 1V, are pretty finicky. I suspect the OP isn't going to have too much problems with 3v.
    One last point from me, the current limiting resistor will tell you how much current is flowing through the LEDs. It is basic Ohm's Law, measure the current across it, divide by the resistance, and you have actual measure current. If there is a significant difference between what you are wanting (such as 20ma) and what you are measuring (say 30ma) then you need to go back and look at your basic assumptions.
    Here is a simple circuit you can use to measure Vf of an individual LED.
    The diodes are to prevent giving the LEDs too much back voltage if you connect it backwards (this can blow more sensitive LEDs).
    A tutorial on LEDs and more....
    LEDs, 555s, Flashers, and Light Chasers
  7. vindicate
    Jul 9, 2009
    158
    Speaking of fluctuating voltage. I want to use these in an automotive application. Would it be best to use a voltage regulator or something?
    I know that once the vehicle is running, voltage supply is 13v+.
    I could design the circuit for the higher voltage and just have the LEDs dimmer when the car isn't running. or I could use a regulator. Unless someone else has a better idea.
  8. #12
    Nov 30, 2010
    16,703
    7,338
    Design for the higher voltage. I have noticed over the years that I really don't notice that the lights are dim when the engine is not running because I almost never drive the car without the engine running.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    We no longer support ANY automotive modification topics.
    LED lighting in automotive applications is an "automotive modification" subject.
    The automotive environment is just too environmentally harsh for hobbyists to experiment in; and faults can have disastrous consequences. Even though you might think that the vehicle voltage will remain within a fairly narrow range of 10v-14.5v, there are "load dump" events where the system voltage can exceed 60v. Hobbyists circuits just won't stand up to those kinds of transients.
    So, please don't attempt them.
  10. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
