leds in parallel choosing resistor
Discussion in 'The Projects Forum' started by panayiotis, Mar 5, 2014.
  1. panayiotis
    Feb 25, 2014
    16
    dear sirs
    i want to connect 20 leds in parallel.
    my source is 2x 4.2v batteries parallel
    led voltage white 3.4v 20ma
    in the following page i can find that i need 20 resistors 47ohms
    http://led.linear1.org/led.wiz
    now in other page
    http://www.hebeiltd.com.cn/?p=zz.led.resistor.calculator
    i find out that i need resistor 2ohms 03w
    does it mean that i need 1 resistor for all circuit? or 20 resistors, one to each led as the previous page?
    what i want to do, is to connect in the beginning of the positive wire only one resistor to limit the voltage to all leds. instead 20 resistors , one to each led
    is it possible? i am little confused!
    thanks
  2. shteii01
    Feb 19, 2010
    3,500
    511
    You are making a current divider. The best way to accomplish your goal is to have each LED have its own resistor. So. 20 LED, 20 resistors. The reason this is the best way to do it, is because each LED will be slightly different from other LED, this means that in your current divider some LED will get more current, some LED will get less current. LED that will get more current will be brighter. LED that will get less current will be dimmer. To solve this little problem you can select individual resistors for individual LED, this way each LED will get almost the same amount of current and be as bright as other LED.
    This is wrong. Resistor here does not limit voltage. The job of the resistor is to limit current.
  3. radiohead
    May 28, 2009
    474
    31
    If you parallel LEDs, each LED will require its own resistor. If you connect LEDs in series, you need only one resistor for the series string. Series strings may be paralleled.
    For your circuit, you have a source voltage of 8.4VDC. The LEDs are 3.4V @ .02A. If you put two LEDs in series: 8.4V - 6.8V = 1.6V that the resistor must drop. 1.6 x .02A = 32 Ohms per two LED string. Since 32 Ohms is not a standard value, 33 OVhm resistors will suffice. This way you will use half as many resistors.
    I hope this helps.
  4. shteii01
    Feb 19, 2010
    3,500
    511
    Case 1. Two batteries in series.
    Case 2. Two batteries in parallel.
      File size:
      121.5 KB
      44
      File size:
      120.8 KB
      37
  5. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Perhaps a little excessive unless the guy is super sensitive and can manage to kill himself with 8.4V.
  6. shteii01
    Feb 19, 2010
    3,500
    511
    It is the nature of internetz that you can be anything you want to be.
  7. pwdixon
    Member
    Oct 11, 2012
    488
    56
    I use the internet a lot, I hope it's not going to make me prone to electrocuting myself on a 9V battery, you've got me worried now.
  8. shteii01
    Feb 19, 2010
    3,500
    511
    A healthy sense of paranoia is always healthy.
    ☺7
  9. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  10. panayiotis
    Feb 25, 2014
    16
    i told i have 2x 4.2v batteries.yes but they are in parallel.
    you did not ask you just have big mouth man!
    dont be the smart one!
  11. panayiotis
    Feb 25, 2014
    16
  12. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Now you might have a problem, putting two batteries in parallel can be a problem that might cause them to overheat and that could be a danger. I think anyone would have assumed you were putting the two batteries in series.
  13. panayiotis
    Feb 25, 2014
    16
    hmm ok i want to learn why the cause overheat?
    ( i am just a learner.i want to learn from members in here.i dont know about electronics thats why i ask.please be patient with me!)
  14. shteii01
    Feb 19, 2010
    3,500
    511
    I apologize. I assumed that you were going to use two batteries in series. A bit later I thought to try two batteries in parallel and I got results that you posted. I have updated my post, please look here: http://forum.allaboutcircuits.com/showpost.php?p=704312&postcount=4
  15. panayiotis
    Feb 25, 2014
    16
    thank you sir
    just an advice!
    some people can not accomplished their dreams! i work from 16 and i am 29!
    i never had the money to even think for a university! so electronics for me is google and this awesome page you all create here! so be patient with some people that you understand they dont know well and advice them
