Leds + Guitar Switch
Discussion in 'The Projects Forum' started by Bombadil, Apr 13, 2011.
  1. Bombadil
    Apr 1, 2011
    Would a telecaster (4 way) pickup selector work as a switch for 5mm leds? (not using it for pickups too, just leds, 12 at the most)
    I want to wire up a few tri leds that turn on/on/on/off, at first I figured I would need a 2 way toggle switch (to turn on/off) then a 3 way on/on/on switch for switching the three colors, but I wondered if a single 4 way guitar switch could do the trick? http://www.guitarpartssite.com/Allparts-EP-4374-000-p/EP-4374-000-AP.htm I also found this image of the contacts: http://www.tdpri.com/telephoto/showphoto.php/photo/15774
  2. wayneh
    Sep 9, 2010
    12,375
    3,226
    A big mechanical switch like a guitar's pickup selector may be overkill but otherwise should work fine for switching the small currents needed for normal LEDs. If you get to switching a lot of them, or some higher power ones, you should probably check the ratings on the switch.
    Bombadil likes this.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. Bombadil
    Apr 1, 2011
    Thanks, it looks like I have lots of options then between guitar switches and that rotary switch!
