LEDs, Diodes, and resistors ???
Discussion in 'General Electronics Chat' started by live4soccer7, Feb 4, 2011.
  1. live4soccer7
    Jun 7, 2008
    88
    I have seen a diode and a resistor hooked up with a 12v pre-wired led. Now my question is how come?
    Here is an example: http://www.phenoptix.com/shop/prewired-ultra-bright-blue-p-60.html
    I know a good amount about leds and resistors, but nothing about this. Can someone enlighten me on this perhaps? I have tried searching, but didn't quite come up with much.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Many people either don't know how to calculate the resistors, and/or don't wish to spend the time to solder in a resistor and then add shrink tubing to insulate them properly.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    The diode is so it will survive in reverse. Most LEDs would be killed by 12V in reverse.
  4. live4soccer7
    Jun 7, 2008
    88
    reverse voltage is something generated by the user, in most cases? For example, someone attempting to hook it up backwards. What about in instances where it isn't user generated, I would assume this is possible. For example, a vehicle application, would this present itself there under normal operation or no? Sorry for the questions, I'm just trying to learn a thing or two now.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Mostly it is to make their parts idiot proof. You are not supposed to connect them backwards, but you can count on it happening more than once. The customer would come back and want replacements for free. This prevents this.
  6. marshallf3
    Jul 26, 2010
    2,358
    201
    Not uncommon, I use a lot of similar ones on 24VAC with an additional series resistor.
    If it doesn't work from 12 VDC just reverse the polarity.
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    They are idiot-proof LEDs, and sometimes plain convenient.
    LEDs need to be current limited, which is what the resistor does, different value resistors for different input voltages.
    LEDs are not build to withstand reverse breakdown, hence the extra diode to make sure the polarity is correct.
    If you are 100% sure you have polarity and current correct from the driving circuit, you can save a lot of money by getting just the LEDs.
