Led Vu Voltmeter
Discussion in 'The Projects Forum' started by biscuitownz, Aug 12, 2013.
  1. biscuitownz
    Aug 9, 2013
    25
    I just wanted to share this with you guys, I just built it and it works perfect :)
    Very useful for measuring fast voltage drops that a traditional DMM can't read.
    You can adjust the reading with the pot (100k) to increase/decrease the voltage range. I'll be using mine for a car so I did 11.7v - 14.5v
  2. wayneh
    Sep 9, 2010
    12,391
    3,246
    You should have put this at the end of your other thread on this topic so that it's easier for those that follow to find it.
    Good to hear it works for you.
  3. biscuitownz
    Aug 9, 2013
    25
    The other thread was for audio this one is for voltage.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    Since there is no peak detector, you will only see things slow enough for your eye to see. And LEDs have a persistence so a fast drop will be masked by the residual brightness of the LED.
